ciarpame's avatar
Feb 28, 2016
Upgrading NV+ V2 from 4x2TB to 3x4TB
Would like to upgrade my NV+ V2 from 4x2TB to 3x4TB.   I suppose the best approach is   full backup remove old disks install the new disks one by one and wait for resync (should be fast since ...
  • mdgm-ntgr's avatar
    Feb 28, 2016
    1. Backup your data
    2. Verify your backup is good
    3. Do a Config Backup
    4. Power down, remove the old disks (label order). That way as a last resort you could use these disks to recover your data (not something I would rely on, but nice as a fallback in case something happens to your backup).
    5. Insert all the new disks
    6. If the disks are blank it should automatically do a factory default when you power on, otherwise you will need to do it via the boot menu
    7. Install any add-ons you had installed before the factory default if you still with to use them
    8. Restore your config backup
    9. Restore your data from backup
    Please make sure before you start this process that you have a NV+ v2 by reading How to tell whether I have a Duo v1 or Duo v2 or NV+ v1 or NV+ v2 (the NV+ v1 supports disks up to 2TB in capacity, so it is important to confirm you have the v2).
ProSupport for Business
