nasmk's avatar
nasmk
UpNp not working and DLNA not installing
Hi all,
In RAIDiator 4.2.24 wehen i click on upnp it looks like this:
upnp block is on
When i click on store it go;s :rofl: :rofl: :rofl:
Gone
And upnp wont be available....
Already reinstalled RAIDiator 4.2.24 tried to install readynas DLNA and it wont work Also a reset with reinstal OS wont work.
Who has a ideea
marcel
ps my englisch is pour.... SRRY :neener:
  • StephenB's avatar
    nasmk - the pictures need to be internet-accessible links, as they are not stored in the forum, only referenced. We can't see your images if they are on your home PC.
  • Did you find a solution to this issue? I also have the same issue on and off for the last couple of weeks. Restart normally sorted it, but not anymore. Re-installing OS from boot menu doe not help...
  • I've been having a similar issue since upgrading to 4.2.24. I cannot get any of the streaming services to activate. I click on their option check box to enable them and click apply and then they immediately uncheck and the service does not activate. Also, the DLNA streaming service is gone. Bizarrely, while the iTunes media server also shows unchecked, it seems to actually be working as my Mac can access all the songs from the server from the "pTunes" object in iTunes as usual.
  • I am also having this issue(UpNp not working and ReadyDLNA not displayed in Frontview).
    Looking through the forum, it seems like others are having this problems as well.
    I have updated to RAIDiator version 4.2.25 but that didn't resolve.
    Has anyone found a fix for this yet?
ProSupport for Business
