jonsenge
Jul 24, 2012Aspirant
UPS battery lengths?
I'm new to all of this, so any help would be much appreciated!! I just installed my first UPS battery backup (APC BE550G Back-UPS ES 8 Outlet 550VA 120V). FrontView is showing all systems green on ...
jonsenge
I just double checked. I am indeed plugged into the surge protector + battery backup half of the UPS. I do only have the NV+ and a WD USB hard drive plugged into it. I just rechecked FrontView after updating to the latest firmware and I still have 476 minutes indicated.
If you're only showing 45 minutes on your setup, what could mine mean? Is there any way to test a power failure and rely on the battery, and watch the auto shutdown happen? The suggestion above on testing the shutdown doesn't test the battery backup portion of the rig.
