gyves1
Jun 02, 2016Luminary
UPS issue on RN312 under OS6.5
Hi, I have an issue with my UPS. My readyNAS shows me a warning about the UPS but it's not clear for me, the info is weak. An another strange thing the ups error event is not recorded in my log :-...
Jun 03, 2016Guru - Experienced User
Then you "fixed" it - at least for now.
gyves1
Jun 03, 2016Luminary
Yes, but the root cause is unknown :smileyfrustrated:
A bug? How can I be sure ?
Maybe there is an another log file on ReadyNas with more deep infos ?
- gyves1Jun 03, 2016Luminary
No, if I remember well, I don't have sent the log to Netgear for this issue.
- gyves1Jun 07, 2016Luminary
An another strange events:
When the power was back (after power cut), the UPS was removed then detected...why?
Tue Jun 7 2016 10:49:17 System: New UPS on PortUSB detected. Manufacturer: EATON, Model: Ellipse ECO 1600, Serial: 000000000. Tue Jun 7 2016 10:49:15 System: UPS on PortUSB removed. Manufacturer: EATON, Model: Ellipse ECO 1600, Serial: 000000000. Tue Jun 7 2016 10:06:55 System: Antivirus scanner definition file was updated to 201606070638. Tue Jun 7 2016 10:02:38 System: UPS UPS () is on line power. Tue Jun 7 2016 9:20:55 System: UPS UPS () is on battery power. - StephenBJun 07, 2016Guru - Experienced User
Perhaps get another log before the info rotates out.
Tue Jun 7 2016 10:49:17 System: New UPS on PortUSB detected. Manufacturer: EATON, Model: Ellipse ECO 1600, Serial: 000000000. Tue Jun 7 2016 10:49:15 System: UPS on PortUSB removed. Manufacturer: EATON, Model: Ellipse ECO 1600, Serial: 000000000. Tue Jun 7 2016 10:06:55 System: Antivirus scanner definition file was updated to 201606070638. Tue Jun 7 2016 10:02:38 System: UPS UPS () is on line power. Tue Jun 7 2016 9:20:55 System: UPS UPS () is on battery power. The log info is below:
Jun 07 10:49:08 homedisk kernel: [608306.710990] usb 4-2: usbfs: USBDEVFS_CONTROL failed cmd usbhid-ups rqt 161 rq 1 len 5 ret -75Jun 07 10:49:08 homedisk kernel: [608306.711180] usb usb4-port2: disabled by hub (EMI?), re-enabling...Jun 07 10:49:08 homedisk kernel: [608306.711187] usb 4-2: USB disconnect, device number 6After the port was re-enabled, the UPS is detected and added again. There is only one of these in the log file. This could be the UPS simply not responding for some reason.BTW, I am also seeing a lot of errors like this one:Jun 05 04:27:01 homedisk cron[2170]: (*system*php5) WRONG FILE OWNER (/etc/cron.d/php5)Any thoughts on why these might be happening (some app you might have installled or some ssh work you did).? - gyves1Jun 07, 2016Luminary
StephenB wrote:BTW, I am also seeing a lot of errors like this one:Jun 05 04:27:01 homedisk cron[2170]: (*system*php5) WRONG FILE OWNER (/etc/cron.d/php5)Any thoughts on why these might be happening (some app you might have installled or some ssh work you did).?Only these app are installed: AV+, SMB+, Transmission, iDrive.
Last week, an iDrive helpdesk specialist has taken the ReadyNas in SSH with Putty tthrough a remote control to check an update installation issue.
How we can to verify the root cause or the trigger of this error event?
- gyves1Jun 10, 2016Luminary
In conclusion, this issue still unknown correct?
- StephenBJun 10, 2016Guru - Experienced User
Certainly its new to me, and I am not seeing it on my OS 6 systems. Perhaps PM Skywalker and/or kohdee with a link to the thread. Since it might be idrive, you could also ask whoever you are using for that.
Where did you get transmission from?
I have got the Transmission app from built-in Readynas marketplace, why?
iDrive doesn't use the UPS, it's just a cloud backup.
Do you think there is third party bug with impact on OS ?
StephenB wrote:
gyves1 wrote:In conclusion, this issue still unknown correct?
There are two issues, and probably not related. The first is the original UPS issue, with an unknown root cause. The second is the flood of homedisk cron[2170]: (*system*php5) WRONG FILE OWNER (/etc/cron.d/php5) errors in your logs.
The UPS problem (for better or worse) is not happening at the moment. I am more concerned about the log flood, since we have no idea what implications that error might have. That is quite likely to be a third-party problem.
Do you know when this "cron[2170]: (*system*php5) WRONG FILE OWNER (/etc/cron.d/php5)" issue has started? Where can I find this information in the log?
My goal is to match the starting date of this issue with the Transmission or iDrive.
Thanks
StephenB wrote:
gyves1 wrote:I have got the Transmission app from built-in Readynas marketplace, why?
Look in system.log in the zip you submitted.
The first entry there is 04 June, but it clearly started before then.
- gyves1Jun 13, 2016Luminary
Hi StephenB,
You have right, after an investigation in my RN312 log files, I have found a link between the rror and iDrive
Jun 10 21:51:01 homedisk cron[2170]: (*system*php5) WRONG FILE OWNER (/etc/cron.d/php5)
S root 16372 2170 16372 0 1 80 0 1988 10627 wait Jun10 ? 00:00:00 /usr/sbin/CRON -f
S root 16373 16372 16373 0 1 80 0 668 1080 wait Jun10 ? 00:00:00 /bin/sh -c cd "/apps/idrive/web/idriveIt/user_profile/gyves@outlook.be/Backup/CloudBackup"; /usr/bin/perl /apps/idrive/web/IDrive/.scripts/Backup_Script_IDrive.plThanks a lot !
I will contact now the iDrive support for this third party app
