pst
Nov 27, 2014Tutor
UPS issues in 6.2 -- still not fixed
So I've been expecting that at some point the UPS stuff might finally get fixed. It's still busted in 6.2 so it's time to get serious about debugging it. I am using OS6 on Legacy hardware, so I can...
pst
Nov 27, 2014Tutor
No, neither a reboot or a plug/unplug event keeps the change, and while my edit brings up the ups driver properly, frontview doesn't see it because the ups found doesn't necessarily match the one it's looking for.
Frontview seems to be writing the .conf file, I'm pretty sure whatever it is using for detection/identification code is bad. I didn't strings(1) your netgear binaries yet to find the bad code writing the conf file, as I don't know the structure of frontview.
If you can peek at the source, I might be able to further isolate the problem code.
