lrl1
Aug 26, 2013Aspirant
USB drive not mounted after reboot
My RN102 (just upgraded to OS 6.1.1) has two internal 1TB drives and one 2TB USB3 external drive formatted with NTFS. If I plug in the external drive it is immediately recognized, device (sdc) crea...
lrl1
Aug 29, 2013Aspirant
Thanks for the pointers.
I checked /run/setup_usb_storate.dbg-sdc1 and it contains only stuff written after I unplugged/replugged hours after the reboot - at which time as I said, it mounted up fine. (the boot was around 15:34, and I replugged the drive at 22:09). Contents of that file are pasted below. Judging from the logs posted previously it seems more likely it was not seen in the usb scan at boot. Unless anyone has some other ideas, I will find another chance to reboot and check this debug file again after that.
root@nas:/run# cat setup_usb_storage.dbg-sdc1
Mon Aug 26 22:09:21 2013
Setting up external storage device: sdc1
Getting UID for device sdc1
Returning WWN as UID: 5000C50037B7D6DC
Got filesystem UUID: 74A89BF8A89BB6D8
Returning UID 5000C50037B7D6DC-74A89BF8A89BB6D83
Got description: Seagate ST2000DL003-9VT166
FS type from env is ntfs for sdc1
Trying ufsd mount of sdc1 with options -o noatime,nls=utf8,umask=0
Executing: mount -o noatime,nls=utf8,umask=0 -t ufsd /dev/sdc1 '/media/USB_HDD_1'
mount_output= /dev/sdc1 on /media/USB_HDD_1 type ufsd (rw,noatime,nls=utf8,fmask=0,dmask=0)
Updating /etc/frontview/usb/storage.conf
Adding 5000C50037B7D6DC-74A89BF8A89BB6D83!!USB_HDD_1!!Seagate ST2000DL003-9VT166!!3907029167!!1!!/dev/sdc1!!!!5000!!3:4
REMOVER = /var/run/usb/sdc1
Executing auxiliary scripts
Updating backup LED status
