RonSchmiege
Jan 24, 2016Tutor
USB drives that work with RN104 & firmware 6.4.1 +
Anyone know which USB drives work properly with RN104 & firmware 6.4.1 and up. (Also if you know of one that doesn't work.) I need to replace my USB backup drive, a Seagate GoFlex with USB 3.0 which ...
mdgm-ntgr
Jan 24, 2016NETGEAR Employee Retired
Which USB port is the GoFlex connected to?
Which filesystem is on this USB disk?
Which services and apps are you running?
What problem are you having with the USB disk?
- BrianL2Jan 24, 2016NETGEAR Employee Retired
Hi RonSchmiege,
The RN100 series devices have one front port, USB version 2.0, and 2 rear ports, USB version 3.0. It recognizes USB drives with FAT32, EXT3/4, NTFS and HFS format.
Hope this helps!
Kind regards,
BrianL
NETGEAR Community- StephenBJan 24, 2016Guru - Experienced User
btrfs was just added to 6.4.2 beta.
Skywalker wrote:
- [Beta 1] Recognize BTRFS filesystems in USB drives.
BTW, all this should be in the software manual (and not just the data sheet). It isn't.
- RonSchmiegeJan 25, 2016Tutor
Sounds like this is the answer to my problem. I have the USB drive connected to the front port. I'll try moving it as soon as I get a chance (tomorrow probably) wish I had known this a month ago when I first updated to 4.6.1.
- BrianL2Jan 25, 2016NETGEAR Employee Retired
Hi RonSchmiege,
Just update this thread once you're done testing it.
Kind regards,
BrianL
NETGEAR Community Team
