bodd
Oct 16, 2016Aspirant
USB HDD backup folders not recognized
I use a Freecom 4TB USB HDD for backup of my RN202. The USB HDD has two partitions USB_HDD_5 and USB_HDD_6. I have backup procedures that directs data from the RN202 to these two partitions depending...
- Nov 09, 2016
bodd wrote:
The PC i use i quite new: a laptop LENOVO X1 Carbon Typer 20FB!
That's ruled out then. It is possibly a limitation of the tools you are using.
There have been improvements in NTFS support over past couple of releases - its much faster than it was. Maybe try switching the disk to NTFS?
You might also try R-linux for windows, and see if it behaves the same way.
JennC
Oct 17, 2016NETGEAR Employee Retired
Hello bodd,
Please try other USB ports of the NAS and let us know. What is the file system format of the USB HDD, by the way?
Welcome to the community!
bodd
Oct 19, 2016Aspirant
Hi
Same result for lower rear and front USB port. The upper rear port – the USB HDD is not detected at all (maybe because the HDD is USB 3.0?). The format used on both partitions is EXT4. I can see both partitions from my PC using Ext2read!
Best,
Jesper
- JennCOct 19, 2016NETGEAR Employee Retired
Hello bodd,
Was this working before updating the firmware version and what was the firmware version prior to the update?
Please also download logs and send them, include the link of this thread.
- boddOct 20, 2016Aspirant
Hi
It was working prior to the upgrade. My previous version was the latest before upgrading to 6.6.0 (6.5.2 I think).
I have send the log-files to you, so I hope you can figure out what is going wrong.
Best,
Jesper
- crazy_toyOct 20, 2016NETGEAR Expert
Hello bodd
You can try to insert USB HDD to your PC , to check whether the two partitions is normal
Thanks!
