bodd
Oct 16, 2016Aspirant
USB HDD backup folders not recognized
I use a Freecom 4TB USB HDD for backup of my RN202. The USB HDD has two partitions USB_HDD_5 and USB_HDD_6. I have backup procedures that directs data from the RN202 to these two partitions depending...
- Nov 09, 2016
bodd wrote:
The PC i use i quite new: a laptop LENOVO X1 Carbon Typer 20FB!
That's ruled out then. It is possibly a limitation of the tools you are using.
There have been improvements in NTFS support over past couple of releases - its much faster than it was. Maybe try switching the disk to NTFS?
You might also try R-linux for windows, and see if it behaves the same way.
bodd
Nov 09, 2016Aspirant
Hi
Best,
Jesper
Nov 09, 2016Guru - Experienced User
