xunforgivenx
Oct 11, 2012Aspirant
USB Not attached but accessable i Explorer??
I cant do backups since USB is not attached under Volumes. It´s however fully accessable i Windows Explorer as USB_FLASH_3 :shock: It´s located in the front What am I doing wrong? Need to reset...
xunforgivenx
Correct, its not listed under USB Volume but i can move and delete files from it in WinExpl
I did not plug it in elseywhere, just had to move it fysically to get to some cables.
I´m pretty sure I didnt make a safe removal via the powerbutton :(
