xunforgivenx
Oct 11, 2012Aspirant
USB Not attached but accessable i Explorer??
I cant do backups since USB is not attached under Volumes. It´s however fully accessable i Windows Explorer as USB_FLASH_3 :shock: It´s located in the front What am I doing wrong? Need to reset...
xunforgivenx
Oct 12, 2012Aspirant
Problem solved! :D
Used the addon "Clean_USB_Storage" found on http://www.readynas.com/?page_id=617
Followed instructions and the Duo found the drive directly
