af8
Jul 31, 2016Guide
USB3 backup drive rarely recognized
I have backed up my NAS to a USB3 drive using the rear USB port and it always mounted ok and did an incremental backup. Since 6.5.0 the NAS rarely recognises and mounts the USB3 drive and when it do...
omicron_persei8
Jul 31, 2016Luminary
Can you clarify the relation between the title of the thread and the error you posted?
- af8Jul 31, 2016Guide
Apologies, I know this probably sounds odd, but that wasn't the title I typed. As you can see from the description the problem that I have is about recognition of a USB drive ;-)
- StephenBAug 01, 2016Guru - Experienced User
I took the liberty of re-titling the thread
- mdgm-ntgrAug 01, 2016NETGEAR Employee Retired
Can you connect the USB disk, try running the backup, then download the logs and send them in (see the Sending Logs link in my sig)?
