bhsmith's avatar
bhsmith
Use RN104 with large disks and no or little sync time
I finally got a new NAS to replace my old RN104.  I want to use my RN104 as an offsite backup. The backup will be a backup of a backup so the data isn’t super critical. The new NAS is six bay and wil...
  • StephenB's avatar
    Aug 02, 2023
    You can eliminate sync time by using FlexRAID and setting up two jbod volumes (with no RAID redundancy).
    One downside is that you can't expand a jbod volume, so if you do run out of space you'd need to export it, install a bigger jbod volume, and copy all the data back.  Though in the case of an RN104 with 2x20 TB you could just set up a third jbod volume instead.
    There is no known limit for disk size with OS-6, so this should work.  Make sure the disks are SATA and not SAS.
ProSupport for Business
