semola1
Feb 14, 2018Tutor
Users and Groups
Hi all, I need an advice to solve a problem. I have added a new user (user group) to a shared folder (only with SMB protocol). When I try to open this folder from windows with this user, I obtain a...
- Feb 16, 2018
I misread your last indication, I tried the two things you told me separately and, in that way, it did not work.
I tried again and now I can log in. I do not like excessively having "everyone" on file permissions, but that works.
Thanks
Marcello
Feb 14, 2018Guru - Experienced User
Normally you should add the group on the network access tab, and allow full access to everyone on the file access tab. Windows (and the NAS) intersect the permissions, so the stricter ones should apply. So look at that first.
Windows also only allows one set of credentials to be used with the NAS at a time. So try running CMD and then enter net use * /delete
That terminates any open SMB sessions in the PC. After that try your test again from Windows Explorer.
If it still fails, try
net use * /delete
net use t: \\nas-ip-address\sharename /user:username userpassword
with the IP address of the NAS and the sharename you have having trouble with. Username is a NAS account that is in the group, and userpassword is the associated password. Be careful with the slash direction and spaces.
semola1
Feb 14, 2018Tutor
I have tryed as you suggest, but I have the same error.
When I execute "net use * /delete" I don't delete any connection and I don't have any error.
When I execute "net use t: \\nas-ip-address\sharename /user:username userpassword" the operation was succesful. If I try to open t: with windows explorer or change the letter unit in the command prompt, I obtain the "folder access error".
I don't understand why if I change the Group at username (from users to Admins), windows can access to shared folder. When I restore the original group, I cannot access to shared folder.
Marcello
- StephenBFeb 14, 2018Guru - Experienced User
Can you post screenshots of share settings - both the network access and file access tabs?
