semola1
Feb 14, 2018Tutor
Users and Groups
Hi all, I need an advice to solve a problem. I have added a new user (user group) to a shared folder (only with SMB protocol). When I try to open this folder from windows with this user, I obtain a...
- Feb 16, 2018
I misread your last indication, I tried the two things you told me separately and, in that way, it did not work.
I tried again and now I can log in. I do not like excessively having "everyone" on file permissions, but that works.
Thanks
Marcello
semola1
Feb 15, 2018Tutor
Only inserting my user into admin group, I can access the shared folder.
In all other configuration I offen have the same access denied error.
I don't know what I can try anymore.
Thanks
Marcello
semola1
Feb 16, 2018Tutor
Thanks
Marcello
- semola1Feb 16, 2018Tutor
it's correct.
I know that even authorizing "everyone" to access all the files isn't dangerous because I filter upstream the shares.
I do not understand, however, why it does not work by authorizing both folders and files to a single user.
Just for curiosity.
Marcello
- StephenBFeb 16, 2018Guru - Experienced User
I'm not completely sure what the issue was in your case. Changing the file access in the web UI doesn't recursively apply those changes to all the files and subfolders in the share, so it's best done when the share is empty. There's also the question of file ownership.
If you want to delve into the details of the file attributes and the ACL that the NAS applies, you probably need to enable ssh, and take a deeper dive from the linux command line.
