bogdahn
Apr 10, 2018Aspirant
Using large HDD on readynas DUO V1
Hello, I would like to use large disks in my Readynas DUO V1, but it cant see more than 1.5To/disk. It's a common formating problem. I tried to install the ssh pluggin, but when i log in, the cl...
Apr 10, 2018Guru - Experienced User
What firmware is the NAS running?
A duo v1 can use a 2 TB drive (which I use in my own Duo). But it can't handle disks larger than that (since it doesn't support GPT or advanced format disks). There is no workaround.
bogdahn wrote:
I tried to install the ssh pluggin, but when i log in, the client close of with no error.
I know it's a debian inside the device, but how to use it as root ?
As noted above, ssh won't help you use disks > 2 TB.
However, your issue is almost certainly that you are using the wrong username. You log in as root, using the NAS admin password.
