bogdahn
Apr 10, 2018Aspirant
Using large HDD on readynas DUO V1
Hello, I would like to use large disks in my Readynas DUO V1, but it cant see more than 1.5To/disk. It's a common formating problem. I tried to install the ssh pluggin, but when i log in, the cl...
Marc_V
Apr 10, 2018NETGEAR Employee Retired
Hi bogdahn
Welcome to the Community!
ReadyNAS Duo V1 is limited to 2TB/To disks, You may want to use root and the admin password of the NAS for access.
bogdahn
Thanks for your replies.
Is it a a SATA controler limitation ?
- Marc_VApr 10, 2018NETGEAR Employee Retired
Hi bogdahn
Duo V1 has no support for GPT Format. It was mentioned also by StephenB on this post.
Certain X86 devices from Legacy NAS were able to be converted from MBR to GPT format getting them to support larger capacity disks however for SPARC units like to Duo V1 it was not possible.
You may want to plan on upgrading your NAS Unit to newer models using OS6 if you really want to use larger capacity disks :)
Regards
- StephenBApr 10, 2018Guru - Experienced User
Netgear never disclosed the exact reasons. The Duo goes back to 2008, and the hardware architecture of v1 NAS generally was first released around 2005. The first 3 TB disk drive came to market in 2010.
The v1s have specialized hardware to handle RAID, and I believe that hardware is also in the Duo (even though with 2 bays it can only do RAID-0 and RAID-1). So it could be hardware (sata controller and/or RAID hardware), or it could be firmware, or some combination of the two.
- Marc_VApr 16, 2018NETGEAR Employee Retired
Hi bogdahn
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
