stevenparker0
Oct 04, 2025Aspirant
Using ReadyNAS as backend for lightweight web tools — is it reliable?
Hi everyone, I currently maintain a small web tool (for example a gratuity / end-of-service benefit calculator for users in the UAE), and I’m evaluating options to host user data, logs, JSON stor...
Calculadora22
Mar 30, 2026Aspirant
Great question! I've seen similar lightweight setups work well for small web tools.
For concurrent JSON file access on ReadyNAS, keeping requests under 50 concurrent is generally safe for lightweight tools. Beyond that, you risk I/O bottlenecks.
For firmware updates, the safest approach is to run your custom services inside Docker containers this way firmware updates don't touch your service configuration.
For SSL and token-based auth, a reverse proxy like Nginx sitting in front of your NAS API endpoints works reliably even on low-power hardware.
We actually use a similar minimal backend approach for our calculadora de datas online a date calculation tool for Brazilian users. Keeping all calculation logic client-side and serving only static JSON config files from the backend made it extremely lightweight and reliable under concurrent access. ReadyNAS type setups work perfectly for this kind of architecture.
Hope this helps!
Mar 30, 2026Guru - Experienced User
Calculadora22 wrote:ReadyNAS type setups work perfectly for this kind of architecture.
They are all EoL, and haven't gotten security updates for a couple of years now. I do not recommend connecting them to the open internet.
