_frantic_
May 19, 2016Aspirant
Using ReadyNAS Replicate with OS 6.5.0
I am using Replicate to backup from my RN312 to a RN104. Both devices have been upgraded from latest 6.4 to 6.5.0. I am not able to get Replicate working again. Is there some documentation? ...
- Aug 03, 2016
Hi _frantic_,
Since you've performed FD, wait for the resync process to complete then add 8.8.8.8 DNS in the active NIC of your system. Once this is done, try to login again your old ReadyNAS Remote/Replicate ID credentials and see if it will accept it.
Kind regards,
BrianL
NETGEAR Community Team
_frantic_
May 20, 2016Aspirant
Thanks for those infos.
1) I am trying to understand: since 6.5, I have to activate ReadyCLOUD on my devices instead of ReadyNAS Remote. ReadyCLOUD uses MyNetgear credentials. The service seems to know about a connection between my MyNetgear account and my ReadyNAS Replicate ID, correct?
4) strange, but you were right: login to replicate.readynas.com does work with my Replicate User (Replicate ID) + password from MyNetgear account.
Backup jobs do not work. Both schedules and manually started.
Example error message:
[2016-05-20 16:45:37] [Error] Connect error code: -501 [2016-05-20 16:45:37] [Error] Please check network connection between devices
I can see both devices on replicate.readynas.com / views / network.
They are on the same network, same switch.
Perhaps a problem with the service (?).
"wait and see" might be a good idea.
kohdee
May 20, 2016Administrator
[2016-05-20 16:45:37] [Error] Connect error code: -501 [2016-05-20 16:45:37] [Error] Please check network connection between devicesI can see both devices on replicate.readynas.com / views / network.
1&4) ReadyNAS Remote functionality rolled into ReadyCLOUD. For RAIDiator devices and OS 6 devices before 6.5.0, you can continue to use Remote client, but for OS 6.5.0, you should be on ReadyCLOUD client. ReadyCLOUD and ReadyNAS Remote are not compatible with each other so you cannot install and run at the same time. For whatever reason, MyNETGEAR updates the ReadyNAS Remote ID + ReadyCLOUD password to match the MyNETGEAR account.
Regarding your backup jobs failing, it could be as simple as restarting both devices. Otherwise, is it doing a local LAN connection or trying to use P2P?
