_frantic_
May 19, 2016Aspirant
Using ReadyNAS Replicate with OS 6.5.0
I am using Replicate to backup from my RN312 to a RN104. Both devices have been upgraded from latest 6.4 to 6.5.0. I am not able to get Replicate working again. Is there some documentation? ...
- Aug 03, 2016
Hi _frantic_,
Since you've performed FD, wait for the resync process to complete then add 8.8.8.8 DNS in the active NIC of your system. Once this is done, try to login again your old ReadyNAS Remote/Replicate ID credentials and see if it will accept it.
Kind regards,
BrianL
NETGEAR Community Team
_frantic_
May 23, 2016Aspirant
I added another test job. Same devices, opposite direction.
Good news: works fine.
Details:
[2016-05-23 19:29:31] [Info] Replicate version: 1.3.0 build R2 [2016-05-23 19:29:31] [Info] Starting backup job "Testjob RN104 - RN312" [2016-05-23 19:29:31] [Info] Create target folder: /data/Backup/Testjob RN104 - RN312 [2016-05-23 19:29:31] [Info] Locking target folder: /data/Backup/Testjob RN104 - RN312 [2016-05-23 19:29:32] [Info] Making full backup [2016-05-23 19:29:32] [Info] p2p connect to nas-34-DD-BC_*** in *** network [2016-05-23 19:29:37] [Info] Connection method: 2 [2016-05-23 19:29:37] [Info] LAN connection available [2016-05-23 19:29:37] [Info] Get LAN credentials [2016-05-23 19:29:37] [Info] Sending task to source device [2016-05-23 19:29:39] [Info] Awaiting task report [2016-05-23 19:29:43] [Info] Received success report [2016-05-23 19:29:43] [Info] Using LAN connection [2016-05-23 19:29:43] [Info] Initializing source device [2016-05-23 19:29:43] [Info] Sending task to source device [2016-05-23 19:29:45] [Info] Awaiting task report [2016-05-23 19:29:48] [Info] Received success report [2016-05-23 19:29:48] [Info] Device initialization finished [2016-05-23 19:29:48] [Info] Copy in progress [2016-05-23 19:29:58] [Info] Copy finished [2016-05-23 19:29:58] [Info] Rotate backups (5) [2016-05-23 19:29:58] [Info] Deinitialize source device [2016-05-23 19:29:58] [Info] Sending task to source device [2016-05-23 19:30:00] [Info] Awaiting task report [2016-05-23 19:30:03] [Info] Received success report [2016-05-23 19:30:03] [Info] Device deinitialization finished [2016-05-23 19:30:03] [Info] p2p disconnect with nas-34-DD-BC_*** in *** network [2016-05-23 19:30:04] [Info] Unlock target folder: /data/Backup/Testjob RN104 - RN312 [2016-05-23 19:30:04] [Info] Job finished
Can I do anything to get my original jobs running again / should I wait some more days?
_frantic_
May 27, 2016Aspirant
I finally found this document: http://kb.netgear.com/app/answers/detail/a_id/29751
According to this, you can use Relicate without having ReadyCloud.
That is good news: I was able to leave ReadyCloud from both devices and Replicate is still available.
(I then renamed local user accounts on both devices back to their original state - joining ReadyCloud had renamed them without asking and then they were no longer accessible via SMB.)
Unfortunateley, still no backup jobs are working from my main device RN312 to the backup device RN104.
A test job in the other direction does work.
I noticed, that ssh and sftp sessions are no longer possible between my Mac and the RN104. It is also not possible to ssh or sftp from the RN312 to the RN104. Strange. Perhaps something seems to be broken on the RN104 since updating from 6.4.2 to 6.5.0.
