gagagu
Jan 27, 2016Aspirant
Using Rsync for Strato Hidrive
Hi, i want to use the rsync protocoll to backup my readynas 2100 to strato hidrive. I'm using the following configuration (user and foldername are replaced with <>): Host: rsync.hidrive.stra...
- Jan 27, 2016
Hi, i have found the issue. SSH was enabled on Hidrive and i'm without ssh atm. (for tests). It seems to work now.
Thx
Jan 27, 2016Guru - Experienced User
Check the source share on the 2100 and make sure that rsync is enabled for it. Stay with /users/<my username>/<foldername> in the path field.
gagagu
Thx
