Aranol
Aug 24, 2018Aspirant
Using RSYNC over SSH to replace NETGEAR Replicate services
Hello, I Try to use the RSYNC over SSH to replace the Netgeat replicase service that stop end 2018
I have follow this tuto https://kb.netgear.com/29929/ReadyNAS-OS-6-Setting-up-a-backup-job-wi...
- Sep 09, 2018
Have you solved your problem? You can try this method, as shown in the figure: checked "Allow shell access" and unchecked "rsyc only" option.
Aranol
Aug 27, 2018Aspirant
This is the screen I have after clicking on "browse"
If I don't use it, and use the "test conection", I've got an error message "impossible connection with host"
Aranol
I also made test with classic RSYNC protocol on port 873, it work perfectly fine, but it's less secure
- AranolSep 03, 2018Aspirant
Here is the error log I have if I dont care about the "browse" button, and the error message of the "test connexion" button, and run the task
Backup Job Name: job_001
Backup Job Type: Incremental
Protocol: rsync+ssh
Backup Source: [DUN_COMMUN]/
Backup Destination: [remote:rsync+ssh]/192.168.1.159://TEST
Backup Start Time: Mon Sep 3 2018 9:29:09
Backup Finish Time: Mon Sep 3 2018 9:29:14
Backup Status: Fail: Error in data stream. Check remote Rsync server settings.Failed to run rsync, return rc 12
'rsync' command returns rc=12The ReadyNAS OS volume cannot be used as an rsync source or destination.
rsync: connection unexpectedly closed (0 bytes received so far) [sender]
rsync error: error in rsync protocol data stream (code 12) at io.c(235) [sender=3.1.2]I've put the 2 NAS on same local network to be sure there is not problem of firewall
I've test the setting in RSYNC, it's work fine
