Aranol
Aug 24, 2018Aspirant
Using RSYNC over SSH to replace NETGEAR Replicate services
Hello, I Try to use the RSYNC over SSH to replace the Netgeat replicase service that stop end 2018
I have follow this tuto https://kb.netgear.com/29929/ReadyNAS-OS-6-Setting-up-a-backup-job-wi...
- Sep 09, 2018
Have you solved your problem? You can try this method, as shown in the figure: checked "Allow shell access" and unchecked "rsyc only" option.
Aranol
Sep 04, 2018Aspirant
I can't NAS refuse anything that did not start by /
Sep 05, 2018Guru - Experienced User
I don't use rsync-over-ssh, but I do use rsync backup jobs extensively. With normal rsync backup, remote Destination shares don't use slashes. Local source shares have the path set to /
