ReadyNASty
Apr 10, 2013Aspirant
Vista Home Premium/Duo V2 - mapped connection dropping
Hello-- Not sure where to start on fixing this. I've already Googled and tried a few solutions (including this one http://support.microsoft.com/kb/297684) even though none seem to apply to my exact...
Apr 11, 2013Guru - Experienced User
Correct. Technically all the addresses are dynamic, with the router managing the assignments. That is one benefit of doing it in the router, and not assigning addresses in each device.
ReadyNASty wrote: So, there are other wireless devices in the house that are getting dynamic addresses, but if the router has 11.2 manually reserved for the Duo v2, shouldn't be a problem, right? (Spouse has her tablet on right now, it's at 11.4; laptop I'm on is again at 11.5, like it was last night.
This helps. WiFi connectivity of course can be blocked by interference, etc. and I wanted to confirm that that the basic issue here is over ethernet. There are probably some ethernet stats on the v2 (I don't own a v2, so I don't know how extensive they are). Your router also keeps some stats (pg 54). It would be helpful to look at both.
"I'm not sure what you mean by Are all your connection drops happening when you use WiFi? so maybe I didn't explain my problem clearly. The desktop computer I am using to access the ReadyNAS and the ReadyNAS are side-by-side, both physically connected to the router with cat5e or whatever it is. It is that computer that keeps saying that the connection to drive U has not been restored, then restoring it, then dropping it again, etc. On one occasion I sat staring at the "My Computer" window and watched the drive go from red X to green and then cycle back and forth between red & green about 4 times in the span of a minute or two. That (along with no drops in wireless music streaming from the files on the ReadyNAS, and RAIDar finding the drive) is a sign that makes me think this is purely a Windows OS problem. Another thing that makes me think it is Windows is Googling "mapped network drive disconnects" and seeing how many problems there are with this, although most seem to involve Windows 7 or some other flavor (maybe because I'm the only one stupid enough to be using Vista? :) ) There seem to be a variety of reasons it happens, but none of the scenarios seem exactly like mine. Biggest difference is, they all seem to involve disconnect when drive has been idle for a time interval like 15 minutes, or at boot-up. Mine can happen, like I said, within seconds of finishing ripping a CD to the drive.
It could be helpful, as it isn't clear at this point what is going wrong. It could be a problem with the router, the NAS network interface, the PC network interface, or even a bad cable.
For troubleshooting purposes, when the desktop computer is showing that the drive's connection has not been restored, would there be any value in going to the laptop computer (wirelessly connected) and trying to browse to the drive's IP address to see what result I get?
