ReadyNASty
Apr 10, 2013Aspirant
Vista Home Premium/Duo V2 - mapped connection dropping
Hello-- Not sure where to start on fixing this. I've already Googled and tried a few solutions (including this one http://support.microsoft.com/kb/297684) even though none seem to apply to my exact...
Apr 18, 2013Guru - Experienced User
Yes, This is a "direct connect". The NAS has an autosensing nic, so there is no need for a crossover cable.
If you are using dhcp with the NAS, note it will fail over to 192.168.168.168. You just need to configure the PC to use a suitable static address (for instance, 192.168.168.100, subnet 255.255.255.0)
