Jan 07, 2021Aspirant
Volume Data Degraded
Hello, Since i replaced the Faulty HDD NASbox displaying Status is Degraded. this issue first time come after replaced the HDD.
- Jan 07, 2021
One aspect is that the NAS won't add a formatted disk to the array. So if your disk was formatted (for instance in Windows), you need to select it on the volume tab, and then format it again. If that succeeds, the disk should be added to the array.
Another possibility of course is that the disk is bad. Personally I test my disks in a Windows PC with vendor tools (seatools for seagate, lifeguard for western digital) before I put them in the NAS. I run the extended read test, and follow that up with the full erase/write test.
2007
XRAID.
Jan 07, 2021Guru - Experienced User
- 2007Jan 07, 2021Aspirant
Hi,
i shutdown the NASBOX and removed That New HDD and connected to Windows pc and Re-formatated. and inserted again as it is and now it is showing in Syncing process since inserted.
i have attached the snapshot.
