juz69
May 14, 2015Aspirant
Volume 'data' is Degraded after adding hdd
Hi guys
i am currently using a readynas 316 (older model) which i upgraded firmware on to 6.1.9 about 12 months ago
it has two wd 4tb red nas drives installed and is set in x-raid
It was running fine but yesterday i bought two more wd red 4tb drives to expand it as i was running short on space
I put one of the new drives in slot 3 and it started to rebuild but then after a few hrs the led screen on the nas started to blink and say degraded, i let it run for 24hrs until it had finished rebuilding but it still says degraded
The storage capacity has increased from 3.6tb to 7.27 but the drive in bay 3 is not showing up on the Volumes page ( It was showing up as black when it first started rebuilding)
I was wondering if i should put the other new drive in slot 4 and see if that fixes it?
here is some of the log
Thu May 14 2015 14:53:59
Volume: Volume 'data' is 'DEGRADED'.
Thu May 14 2015 14:53:58
System: ReadyNASOS background service started.
Thu May 14 2015 14:51:03
System: System is shutting down.
Thu May 14 2015 14:23:55
System: External storage device connected.
Thu May 14 2015 14:22:29
System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (540 rpm).
Thu May 14 2015 13:54:20
System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (514 rpm).
Thu May 14 2015 13:49:16
Volume: The rebuild operation has finished on volume 'data'. However, the volume is still degraded.
Thu May 14 2015 13:34:51
System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (496 rpm).
Thu May 14 2015 13:24:26
Thu May 14 2015 13:07:38
Thu May 14 2015 12:58:22
System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (490 rpm).
Thu May 14 2015 12:57:04
Thu May 14 2015 12:46:19
Thu May 14 2015 12:35:26
Thu May 14 2015 12:24:17
Thu May 14 2015 12:08:55
Thu May 14 2015 11:57:37
System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (534 rpm).
Thu May 14 2015 11:46:12
Thu May 14 2015 11:35:00
System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (463 rpm).
Thu May 14 2015 11:23:14
Thu May 14 2015 11:12:11
Thu May 14 2015 11:02:57
System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (484 rpm).
Thu May 14 2015 11:00:45
Thu May 14 2015 10:49:07
Thu May 14 2015 10:37:26
Thu May 14 2015 10:25:59
Thu May 14 2015 10:16:15
Thu May 14 2015 10:14:33
Thu May 14 2015 10:02:57
Thu May 14 2015 9:51:16
Thu May 14 2015 9:39:40
Thu May 14 2015 9:29:49
Thu May 14 2015 9:28:09
Thu May 14 2015 9:16:40
Thu May 14 2015 9:05:00
Thu May 14 2015 8:53:27
System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (520 rpm).
Thu May 14 2015 8:43:47
Thu May 14 2015 8:42:08
Thu May 14 2015 8:30:30
Thu May 14 2015 8:19:05
Thu May 14 2015 8:07:26
Thu May 14 2015 7:57:31
Thu May 14 2015 7:55:51
Thu May 14 2015 7:44:18
Thu May 14 2015 7:32:48
Thu May 14 2015 7:10:34
Thu May 14 2015 7:06:30
Thu May 14 2015 6:40:37
System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (502 rpm).
Thu May 14 2015 6:17:04
Thu May 14 2015 2:39:11
Thu May 14 2015 1:24:34
System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (468 rpm).
Thu May 14 2015 1:00:20
Thu May 14 2015 0:46:09
Thu May 14 2015 0:14:42
System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (305 rpm).
Thu May 14 2015 0:12:08
Thu May 14 2015 0:02:04
Miscellaneous: Snapshot 'c_1431525719' is successfully created for share or LUN 'S_Music'.
Thu May 14 2015 0:01:50
Miscellaneous: Snapshot 'c_1431525705' is successfully created for share or LUN 'S_Movies'.
Thu May 14 2015 0:01:35
Miscellaneous: Snapshot 'c_1431525689' is successfully created for share or LUN 'S_Juz'.
Thu May 14 2015 0:01:19
Miscellaneous: Snapshot 'c_1431525674' is successfully created for share or LUN 'S_HomeMovies'.
Thu May 14 2015 0:01:04
Miscellaneous: Snapshot 'c_1431525663' is successfully created for share or LUN 'S_Fishing'.
Thu May 14 2015 0:01:02
Miscellaneous: Snapshot 'c_1431525661' is successfully created for share or LUN 'S_Documents'.
Thu May 14 2015 0:01:01
Miscellaneous: Snapshot 'c_1431525661' is successfully created for share or LUN 'GrovesUser'.
Thu May 14 2015 0:01:00
Miscellaneous: Snapshot 'c_1431525659' is successfully created for share or LUN 'Backup'.
Wed May
:38:25
Wed May
:16:04
System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (0 rpm).
Wed May
:49:28
System: Alert configuration has been saved.
Wed May
:49:28
System: Alert settings have been updated.
Wed May
:49:20
System: Alert contact information has been saved.
Wed May
:44:18
Volume: Rebuilding started for Volume 'data'.
Wed May
:44:05
Wed May
:44:03
Wed May
:44:00
Volume: Volume 'data' usage exceeds 90 % of size (3.6 TB).
Wed May
:36:21
Wed May
:34:22
Wed May
:34:11
Wed May
:34:08
Wed May
:34:06
Wed May
:23:37
Wed May
:19:05
Wed May
:18:35
Wed May
:18:32
Wed May
:18:29
Wed May
:14:49
Wed May
:11:55
Wed May
:56:41
Disk: System will be shut down in 30 minutes because of disk failure.
Wed May
:56:36
Volume: Volume 'data' health changed from 'REDUNDANT' to 'DEGRADED'.
Wed May
:56:33
Disk: Disk Model:WDC WD40EFRX-68WT0N0 Serial:WD-WCC4E4ZJ9J71 has been removed from Channel '3' of the head unit.
Wed May
:56:13
Disk: Disk in channel '3' (Internal) changed state from ONLINE to FAILED.
Wed May
:51:31
Wed May
:47:05
Wed May
:35:53
Wed May
:35:30
Wed May
:21:38
Wed May
:05:28
Wed May
:49:41
Wed May
:49:29
Wed May
:38:07
Wed May
:24:17
Wed May
:12:43
Wed May
:59:11
Wed May
:47:47
Wed May
:47:36
Wed May
:33:44
Wed May
:22:12
Wed May
:10:49
Wed May
:59:15
Wed May
:47:43
Wed May
:36:11
Wed May
:24:40
Wed May
:10:50
Wed May
:59:55
Wed May
:59:21
Wed May
:47:48
Wed May
:36:16
Wed May
:24:57
System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (527 rpm).
Wed May
:13:48
Wed May
:13:14
Wed May
:01:42
Wed May
:50:12
Wed May
:38:43
Wed May
:27:48
Wed May
:27:13
Wed May
:06:31
Wed May
:43:33
Wed May
:11:06
Wed May
:10:31
Wed May
:10:30
Wed May
:10:28
System: ReadyNASOS service or process was restarted.
Wed May
:21:05
Wed May
:20:36
Disk: Disk Model:WDC WD40EFRX-68WT0N0 Serial:WD-WCC4E4ZJ9J71 has been added to Channel '3' of the head unit.
Wed May
:04:58
System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (310 rpm).
Wed May
:02:31
Wed May
:41:53
Wed May
:41:23
- de_niroGuideI'll PM you my email address,please email me logs to verify the issue.
- juz69AspirantI turned it off
Removed drive 3 and reinstalled
Then turned it back on
Now it is showing up and says rebuilding
At 33% so far and still going
Will post the results tomorrow afternoon - juz69AspirantFixed
Dont know how or why but after removing and reinserting the drive it started to resync and after 8 hrs its showing up and is working fine
Now to install the next drive and hope it goes well
