stbatpierret
Sep 13, 2021Aspirant
Volume error on readynas 4220
Dear, I just received an error "System volume tmpfs's usage is 89%. This condition should not occur under normal conditions. Contact technical support." Logged with ssh i found root@nas-4220-1...
Sep 13, 2021Guru - Experienced User
Not sure where those files are coming from.
But I am wondering if you have tried rebooting the NAS? tmpfs is a temporary file system (like a ramdisk, but it can be swapped out).
- stbatpierretSep 13, 2021Aspirant
Thanks for the info
I carefuly moved these files to a temp directory and partition space recovered to something normal.
I still do not understand why these files were created.
I will continue to check in the folliwing days.
