powellandy1
Jan 12, 2017Virtuoso
Volume is degraded (but all disks green)
Hi I have a Pro6 on OS6.6.1 It did have 4x4TB and 2x6TB. I upgraded disk 1 to 6TB - all went fine and it resync'd in about 24h - free space shows correctly 4TB of 22TB. I then upgraded disk 2 ...
- Jan 28, 2017
mdstat shows 6 TB in md126 and 20 TB in md127 - btw that is backwards from what I'd expect to see. That totals 26 TB (23.6 TiB), which is what it should be.
Your btrfs fi show output includes
devid 2 size 3.64TiB used 1.33TiB path /dev/md126
which is 2 TB short (as you say).
Try btrfs fi resize 2:max /data as there are some posts out there that say you sometimes do need to specify the device id that you want to resize.
mdgm-ntgr
Jan 13, 2017NETGEAR Employee Retired
Wow you have a really long firmware update history on this unit.
Is your backup up to date?
- powellandy1Jan 28, 2017Virtuoso
Update:
mdgm and Skywalker kindly PM'd. Skywalker accessed remotely and issued a mdadm command to force the array down to 6 disks and convert back to RAID5. It looks like the issue was OS6 hadn't marked the disk as failed when it was removed before I swapped the new one in. That has now reshaped BUT.... it looks like btrfs hasn't resized correctly and I'm left 2TB short.
I've done a
btrfs fi resize max /data
as suggested by mdgm. I've also balanced the metadata and tried the resize again. Thrown in a few reboots as well!
Various outputs below.
Any advice gratefully received
Thanks
Andy
root@Pro6:~# cat /proc/mdstat Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] md126 : active raid5 sde4[0] sdb4[3] sda4[2] sdf4[1] 5860124736 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU] md127 : active raid5 sdd3[0] sde3[4] sdf3[5] sda3[6] sdb3[7] sdc3[1] 19510833920 blocks super 1.2 level 5, 64k chunk, algorithm 2 [6/6] [UUUUUU] md1 : active raid6 sda2[0] sdb2[5] sdf2[4] sde2[3] sdd2[2] sdc2[1] 2093056 blocks super 1.2 level 6, 512k chunk, algorithm 2 [6/6] [UUUUUU] md0 : active raid1 sdd1[0] sde1[4] sdf1[5] sda1[6] sdb1[7] sdc1[1] 4190208 blocks super 1.2 [6/6] [UUUUUU] unused devices: <none> root@Pro6:~# mdadm --detail /dev/md127 /dev/md127: Version : 1.2 Creation Time : Thu Feb 13 19:50:29 2014 Raid Level : raid5 Array Size : 19510833920 (18606.98 GiB 19979.09 GB) Used Dev Size : 3902166784 (3721.40 GiB 3995.82 GB) Raid Devices : 6 Total Devices : 6 Persistence : Superblock is persistent Update Time : Sat Jan 28 10:53:58 2017 State : clean Active Devices : 6 Working Devices : 6 Failed Devices : 0 Spare Devices : 0 Layout : left-symmetric Chunk Size : 64K Name : 33ea2557:data-0 (local to host 33ea2557) UUID : 92b2bc5f:cf375e4b:5dcb468f:89d2bd81 Events : 13329989 Number Major Minor RaidDevice State 0 8 51 0 active sync /dev/sdd3 1 8 35 1 active sync /dev/sdc3 7 8 19 2 active sync /dev/sdb3 6 8 3 3 active sync /dev/sda3 5 8 83 4 active sync /dev/sdf3 4 8 67 5 active sync /dev/sde3 root@Pro6:~# mdadm --detail /dev/md126 /dev/md126: Version : 1.2 Creation Time : Tue Nov 24 12:23:49 2015 Raid Level : raid5 Array Size : 5860124736 (5588.65 GiB 6000.77 GB) Used Dev Size : 1953374912 (1862.88 GiB 2000.26 GB) Raid Devices : 4 Total Devices : 4 Persistence : Superblock is persistent Update Time : Sat Jan 28 10:53:57 2017 State : clean Active Devices : 4 Working Devices : 4 Failed Devices : 0 Spare Devices : 0 Layout : left-symmetric Chunk Size : 64K Name : 33ea2557:data-1 (local to host 33ea2557) UUID : 4010d079:27f07b46:33b86d75:a3989442 Events : 6475 Number Major Minor RaidDevice State 0 8 68 0 active sync /dev/sde4 1 8 84 1 active sync /dev/sdf4 2 8 4 2 active sync /dev/sda4 3 8 20 3 active sync /dev/sdb4 root@Pro6:~# btrfs fi show Label: '33ea2557:data' uuid: 71e6eb17-3915-4aa1-bf47-ee05fec2bcd2 Total devices 2 FS bytes used 18.09TiB devid 1 size 18.17TiB used 17.16TiB path /dev/md127 devid 2 size 3.64TiB used 1.33TiB path /dev/md126 root@Pro6:~# btrfs fi df /data Data, single: total=18.47TiB, used=18.08TiB System, RAID1: total=32.00MiB, used=2.03MiB Metadata, RAID1: total=13.00GiB, used=11.57GiB GlobalReserve, single: total=512.00MiB, used=0.00B root@Pro6:~# df -h Filesystem Size Used Avail Use% Mounted on udev 10M 4.0K 10M 1% /dev /dev/md0 4.0G 721M 3.0G 20% / tmpfs 998M 0 998M 0% /dev/shm tmpfs 998M 6.0M 992M 1% /run tmpfs 499M 1004K 498M 1% /run/lock tmpfs 998M 0 998M 0% /sys/fs/cgroup /dev/md127 22T 19T 3.8T 84% /data /dev/md127 22T 19T 3.8T 84% /home /dev/md127 22T 19T 3.8T 84% /apps- StephenBJan 28, 2017Guru - Experienced User
