powellandy1
Jan 12, 2017Virtuoso
Volume is degraded (but all disks green)
Hi I have a Pro6 on OS6.6.1 It did have 4x4TB and 2x6TB. I upgraded disk 1 to 6TB - all went fine and it resync'd in about 24h - free space shows correctly 4TB of 22TB. I then upgraded disk 2 ...
- Jan 28, 2017
mdstat shows 6 TB in md126 and 20 TB in md127 - btw that is backwards from what I'd expect to see. That totals 26 TB (23.6 TiB), which is what it should be.
Your btrfs fi show output includes
devid 2 size 3.64TiB used 1.33TiB path /dev/md126
which is 2 TB short (as you say).
Try btrfs fi resize 2:max /data as there are some posts out there that say you sometimes do need to specify the device id that you want to resize.
powellandy1
Jan 28, 2017Virtuoso
Update:
mdgm and Skywalker kindly PM'd. Skywalker accessed remotely and issued a mdadm command to force the array down to 6 disks and convert back to RAID5. It looks like the issue was OS6 hadn't marked the disk as failed when it was removed before I swapped the new one in. That has now reshaped BUT.... it looks like btrfs hasn't resized correctly and I'm left 2TB short.
I've done a
btrfs fi resize max /data
as suggested by mdgm. I've also balanced the metadata and tried the resize again. Thrown in a few reboots as well!
Various outputs below.
Any advice gratefully received
Thanks
Andy
root@Pro6:~# cat /proc/mdstat
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md126 : active raid5 sde4[0] sdb4[3] sda4[2] sdf4[1]
5860124736 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU]
md127 : active raid5 sdd3[0] sde3[4] sdf3[5] sda3[6] sdb3[7] sdc3[1]
19510833920 blocks super 1.2 level 5, 64k chunk, algorithm 2 [6/6] [UUUUUU]
md1 : active raid6 sda2[0] sdb2[5] sdf2[4] sde2[3] sdd2[2] sdc2[1]
2093056 blocks super 1.2 level 6, 512k chunk, algorithm 2 [6/6] [UUUUUU]
md0 : active raid1 sdd1[0] sde1[4] sdf1[5] sda1[6] sdb1[7] sdc1[1]
4190208 blocks super 1.2 [6/6] [UUUUUU]
unused devices: <none>
root@Pro6:~# mdadm --detail /dev/md127
/dev/md127:
Version : 1.2
Creation Time : Thu Feb 13 19:50:29 2014
Raid Level : raid5
Array Size : 19510833920 (18606.98 GiB 19979.09 GB)
Used Dev Size : 3902166784 (3721.40 GiB 3995.82 GB)
Raid Devices : 6
Total Devices : 6
Persistence : Superblock is persistent
Update Time : Sat Jan 28 10:53:58 2017
State : clean
Active Devices : 6
Working Devices : 6
Failed Devices : 0
Spare Devices : 0
Layout : left-symmetric
Chunk Size : 64K
Name : 33ea2557:data-0 (local to host 33ea2557)
UUID : 92b2bc5f:cf375e4b:5dcb468f:89d2bd81
Events : 13329989
Number Major Minor RaidDevice State
0 8 51 0 active sync /dev/sdd3
1 8 35 1 active sync /dev/sdc3
7 8 19 2 active sync /dev/sdb3
6 8 3 3 active sync /dev/sda3
5 8 83 4 active sync /dev/sdf3
4 8 67 5 active sync /dev/sde3
root@Pro6:~# mdadm --detail /dev/md126
/dev/md126:
Version : 1.2
Creation Time : Tue Nov 24 12:23:49 2015
Raid Level : raid5
Array Size : 5860124736 (5588.65 GiB 6000.77 GB)
Used Dev Size : 1953374912 (1862.88 GiB 2000.26 GB)
Raid Devices : 4
Total Devices : 4
Update Time : Sat Jan 28 10:53:57 2017
State : clean
Active Devices : 4
Working Devices : 4
Failed Devices : 0
Spare Devices : 0
Chunk Size : 64K
Name : 33ea2557:data-1 (local to host 33ea2557)
UUID : 4010d079:27f07b46:33b86d75:a3989442
Events : 6475
0 8 68 0 active sync /dev/sde4
1 8 84 1 active sync /dev/sdf4
2 8 4 2 active sync /dev/sda4
3 8 20 3 active sync /dev/sdb4
root@Pro6:~# btrfs fi show
Label: '33ea2557:data' uuid: 71e6eb17-3915-4aa1-bf47-ee05fec2bcd2
Total devices 2 FS bytes used 18.09TiB
devid 1 size 18.17TiB used 17.16TiB path /dev/md127
root@Pro6:~# btrfs fi df /data
Data, single: total=18.47TiB, used=18.08TiB
System, RAID1: total=32.00MiB, used=2.03MiB
Metadata, RAID1: total=13.00GiB, used=11.57GiB
GlobalReserve, single: total=512.00MiB, used=0.00B
root@Pro6:~# df -h
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 721M 3.0G 20% /
tmpfs 998M 0 998M 0% /dev/shm
tmpfs 998M 6.0M 992M 1% /run
tmpfs 499M 1004K 498M 1% /run/lock
tmpfs 998M 0 998M 0% /sys/fs/cgroup
/dev/md127 22T 19T 3.8T 84% /data
/dev/md127 22T 19T 3.8T 84% /home
/dev/md127 22T 19T 3.8T 84% /appsStephenB
Jan 28, 2017Guru - Experienced User
