powellandy1's avatar
powellandy1
Virtuoso
Jan 12, 2017
Volume is degraded (but all disks green)
Hi   I have a Pro6 on OS6.6.1 It did have 4x4TB and 2x6TB. I upgraded disk 1 to 6TB - all went fine and it resync'd in about 24h - free space shows correctly 4TB of 22TB. I then upgraded disk 2 ...
  • StephenB's avatar
    Jan 28, 2017
    mdstat shows 6 TB in md126 and 20 TB in md127 - btw that is backwards from what I'd expect to see.  That totals 26 TB (23.6 TiB), which is what it should be.
    Your btrfs fi show output includes
     devid    2 size 3.64TiB used 1.33TiB path /dev/md126
     which is 2 TB short (as you say).
    Try btrfs fi resize 2:max /data as there are some posts out there that say you sometimes do need to specify the device id that you want to resize.
ProSupport for Business
