KillerBob
Jun 13, 2012Aspirant
Volume Maintenance timing
Hi, I am setting up Volume Maintenance, and set both Disk Scrubbing and Online Filesystem Consistency Check for "Every 4 Weeks", on Tuesdays. However, it didn't trigger yesterday, and I wonder how ...
mdgm-ntgr
Jun 13, 2012NETGEAR Employee Retired
The information is in here:
If you don't have SSH access, go to System > Config Backup in Frontview, download the config, extract the zip contents and look at the file. You'll see a timestamp. You can use an epoch time converter on the web (e.g. http://www.epochconverter.com/) to work out when the job was last run.
As you can see I have disk scrubbing scheduled every four weeks and a consistency check scheduled every week. I run the consistency check two hours before the disk scrubbing. Running on the hour works fine for me, but I don't think you can do both checks at the same time.
MDGM-NAS:~# cat /etc/frontview/vol_maint.conf
scrub:/dev/c/c:4:1338656402
consistency:/dev/c/c:1:1339254002
