kenalker
Dec 28, 2014Aspirant
volume scan and quotas in OS6
I bought an RN314 last week which I immediately upgraded to OS V6.2.2. I noticed that the "perform volume scan" and "check and fix quotas on next reboot" options are missing from the RESTART command ...
mdgm-ntgr
Dec 28, 2014NETGEAR Employee Retired
Quotas have been requested before. We will have to wait and see.
As for the other question I'm not sure.
I do know at least on 6.2.x if an OS re-install is done then a filesystem check of the 4GB root partition is done.
For the data volume it would be advisable to ensure you have an up to date backup. BTRFS has a lot of great features to provide additional protection for your data compared with EXT4, but you are still vulnerable to things such as multiple disk failures, fire, flood and theft.
