kenalker
Dec 28, 2014Aspirant
volume scan and quotas in OS6
I bought an RN314 last week which I immediately upgraded to OS V6.2.2. I noticed that the "perform volume scan" and "check and fix quotas on next reboot" options are missing from the RESTART command ...
kenalker
Where does the root partition reside? Is it on the same four hard drives that come with the RN314? If so, what file system does the root partition use, and what (if any) RAID configuration is it stored on?
