terryc_ms
Nov 05, 2011Follower
Volume scan failed to run properly - after 2 of 4 disks dead
My ReadyNas NVX reported 2 drives dead. The first 2 times I rebotted it would come back intermittently but then after a few mins the drives would be dead again. I tried updating to ther latest firmware but no luck.
Model: ReadyNAS NVX Business Edition [X-RAID2]
Firmware: RAIDiator 4.2.19
Memory: 1024 MB [6-6-6-24 DDR2]
I did an RMA on my 2 drives, but when I put one in and reboot it reports:
-Volume scan failed to run properly.
-The paths for the shares listed below could not be found. Typically, this occurs when the ReadyNAS is unable to access the data volume. media Data backup
From volume log:
===== pvscan =====
Couldn't find device with uuid 'v1SG1V-futO-JfC4-Mf6Q-Wj0G-DpdJ-Ihqt08'.
PV unknown device VG c lvm2 [2.72 TB / 10.00 GB free]
PV /dev/md3 VG c lvm2 [931.50 GB / 0 free]
Total: 2 [1.63 TB] / in use: 2 [1.63 TB] / in no VG: 0 [0 ]
===== vgscan =====
Couldn't find all physical volumes for volume group c.
Volume group "c" not found
Reading all physical volumes. This may take a while...
===== lvscan =====
===== vgdisplay =====
===== fstab =====
# <device> <mount> <type> <options> <freq> <pass>
/dev/md0 / ext3 defaults,noatime,nodiratime 0 0
proc /proc proc defaults 0 0
/dev/md1 swap swap defaults 0 0
/dev/c/c /c ext4 defaults,acl,user_xattr,usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv1,noatime,nodiratime 0 2
Can you tell me what to do? IO have not actually returned the RMA drives yet.
From volume log:
===== pvscan =====
===== vgscan =====
===== lvscan =====
===== fstab =====
- Please contact tech support.
- You said you have RMAed 2 failed disks?
If yes, you have lost your data.
