truittvance
Jul 11, 2012Aspirant
Volume scan
Greetings,
Each time I reboot by readynas pro I get this email:
Volume scan found errors that it could not easily correct. Please ensure that you have current backups of all valuable data before performing a full volume scan by rebooting the NAS through Frontview with the volume scan option enabled.
***** File system check performed at Tue Jul 10 15:49:24 PDT 2012 *****
fsck 1.41.14 (22-Dec-2010)
/dev/c/c contains a file system with errors, check forced.
/dev/c/c: Extended attribute block 169512960 has reference count 4, should be 3.
/dev/c/c: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY.
(i.e., without -a or -p options)
It appears that I need to run fsck manually, anyone know how I should do this?
- OOM-9NETGEAR ExpertI have confirmed this is normal behavior with the newest firmware. You will need to manual command the NAS to run the FSCK. Since the FSCK has helped you in the pasted
We were trying to help control the FSCK from destroying the data. Informing you guys to backup the data before it forces the changes to the FS.
In the meantime, you can run the FSCK manual, or if you wanted to reboot; there is an option to skip FSCK. - truittvanceAspirantOk thats fine, the error message was changed in the update, I got that now. But that brings me back to my original question, how do I run fsck manually and will that help correct whatever problem I am having? As I have already stated, it runs automatically every time I boot now and takes a few hours and gives me the same error message every time. I would like to eliminate this behaviour.
Restating the same issue in a different way: The problem is the unit runs fsck every time it boots and sends me the error, I no longer can control that whether it goes through fsck or not, it goes through fsck regardless. How can I eliminate this behavior?
Thanks for your continued help. - StephenBGuru - Experienced UserI am wondering if the volume scans run fsck "manually"
- OOM-9NETGEAR ExpertIt looks like that you have already tried the manual option with the reboot and applying the following option:
*Perform volume scan on next boot. This process can take several minutes to more than an hour depending on disk capacity and volume content.
Let's see if we are able to work something out over pm. - I am having the exact same problem, but I can't determine from this thread if running the reboot option with "Perform volume scan on next boot. This process can take several minutes to more than an hour depending on disk capacity and volume content" actually performs an fsck that writes the changes back?
How do we fix this problem?
