brettgavin
Aug 28, 2012Tutor
Volume Settings Missing Options
Hi, I have two 6-bay Pros at my work. Today, I went to setup snapshots and consistency checks, but I ran into a problem on nas1: The options are not available. On nas2, the options are present. I h...
vandermerwe
Aug 29, 2012Master
1. To get the snapshot screen to reappear you will need to recreate the volume and set up a snapshot at that stage. You will need to backup data first.
2. To get the vol cons check to reappear you must ensure that journalling is enabled. Strangely, I have full data journaling disabled and I have the vol consistency option active. You might want to try different journaling settings.
