Cazzbags
Mar 16, 2019Aspirant
Volume: System volume root's usage is xx%. This condition should not occur under normal conditions.
Hi all
I've found a few miscellaneous posts about similar problems but none that seem to relate here.
I'm getting the log error:
Volume: System volume root's usage is 92%. This condition should...
TikTok90
Mar 17, 2019Star
Hi I seem to be having the same issue. I'm running firmware 6.9.5. I've tried ssh to the device and using the command df -i i get the following in putty:
As far as I can tell from this I don't seem to have a problem as the highest usage is 23%. Can anyone provide any better checks for diagnosis? I'm not an SSH expert so step by step help welcome!
- TikTok90Mar 17, 2019Star
df -h gives
so clearly the /dev/md0 bit is the problem.
- StephenBMar 17, 2019Guru - Experienced User
Perhaps turn Antivirus off and leave it off. Netgear is dropping it for RN100s in 6.10.x anyway. The RN100s only have 512 mb of RAM (compared with at least 2 GB in the other OS-6 platforms).
There is a guideline here that gives some steps for diagnosis: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/RN314-FW-6-7-1-root-partition-full-how-to-fix/m-p/1284659#M130056
You do need to be careful about deleting files, especially if you don't know what they are for. It'd be best to make sure your backup is up to date first.
I've then done:
mount --bind / /mnt du -d1 -h /mnt umount /mnt
This gives:
So the problem seems to be either the 230M /mnt/usr, or the 487 /mnt/Adele
Adele shouldn't be there at all - do you have any idea what it is? It's certainly part of the puzzle (500 MB). If you have another copy of it's contents you should delete it. If not, you can copy it to an existing share on the data volume and then delete the copy in the root. Later on you can put it where you really want it.
But the big problem is /var (2.6 GB) That's about 2 GB more than it should be. So try the mount again and descent into /var. See if you can find where the bulk space is going. When you find the folder, look at the actual file sizes (ls -al), since it might be just one or two files.
