Cazzbags
Mar 16, 2019Aspirant
Volume: System volume root's usage is xx%. This condition should not occur under normal conditions.
Hi all
I've found a few miscellaneous posts about similar problems but none that seem to relate here.
I'm getting the log error:
Volume: System volume root's usage is 92%. This condition should...
TikTok90
Mar 17, 2019Star
df -h gives
so clearly the /dev/md0 bit is the problem.
Mar 17, 2019Guru - Experienced User
Perhaps turn Antivirus off and leave it off. Netgear is dropping it for RN100s in 6.10.x anyway. The RN100s only have 512 mb of RAM (compared with at least 2 GB in the other OS-6 platforms).
There is a guideline here that gives some steps for diagnosis: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/RN314-FW-6-7-1-root-partition-full-how-to-fix/m-p/1284659#M130056
You do need to be careful about deleting files, especially if you don't know what they are for. It'd be best to make sure your backup is up to date first.
