PeteCress
Jan 06, 2011Apprentice
Wake-On-LAN: Anybody Got It Working?
Seems like WOL is the only game in town for remote recovery from a power failure ==> graceful shutdown in response to UPS. I'm doing something wrong, but don't know what. Using Fusion's "FUSION ...
PeteCress
victorhortaliveson wrote: I use this : http://magicpacket.free.fr/
Works fine if I use Subnet Mask 0.0.0.0 and UDP on Port 9, but I am using this on a local network, not via the Internet.
I'm not getting anywhere.
In in FrontView | Services | Standard File Protocols, I have all the protocols except Rsynch enabled.
Tried doing TCP/IP instead of UDP, but kept getting "The requested address is not valid in its context 255.255.255.255.9 - using a subnet mask of 0.0.0.0.
Then I switched to a subnet mask of 255.255.255.255 and things seemed to improve.
Sending a packet with the box turned on, I got a dialog saying that the box had actively refused the packet.
Sending it again with the box off, however, I got "A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 192.168.0.121:9.
Switching back to UDP with 255... I get no response at all.
Reading viewtopic.php?f=24&t=38795, it sounds like I need to do some work on my router for the TCP/IP flavor to work - or even spring for another router (mine is a LinkSys WRT310N, and it does not appear to have native WOL support.... and the mods I've read about so far are way, way, waaaaay above my pay grade).
Stay tuned...
