PeteCress
Jan 06, 2011Apprentice
Wake-On-LAN: Anybody Got It Working?
Seems like WOL is the only game in town for remote recovery from a power failure ==> graceful shutdown in response to UPS. I'm doing something wrong, but don't know what. Using Fusion's "FUSION ...
topo_nas
Jan 07, 2011Aspirant
PeteCress wrote:
ilkevinli wrote: Its very easy to upgrade the firmware. All you have to do is download the firmware file, login to the router, and browse to the firmware file and hit upgrade. The important part is to make sure after the flashing is done that you do the 30/30/30 reset. Also make sure your router model is supported before flashing.
I just pulled the trigger on a Linksys E3000 from B&H photo.
FWIW, their bottom line price was about ten bucks less than Sam's Club....
Another choice for the LinkSys E3000 is dd-wrt, BUT you need to start with the right version of firmware.
Start here: http://www.dd-wrt.com/wiki/index.php/Linksys_E3000
