PeteCress
Jan 06, 2011Apprentice
Wake-On-LAN: Anybody Got It Working?
Seems like WOL is the only game in town for remote recovery from a power failure ==> graceful shutdown in response to UPS. I'm doing something wrong, but don't know what. Using Fusion's "FUSION ...
PeteCress
Jan 23, 2011Apprentice
ilkevinli wrote: Thats odd because it works fine for both my Ultra and Ultra Plus.
Does it work when the device has been shut down by means other than FrontView | System | Shutdown?
I applied a Bios update and behavior has changed.
Namely, sending a magic packet will wake it up as long as it was turned off via FrontView | System | Shutdown.
But if it has been turned off via FrontView | System | Power | Power Timer or by pressing the box's front power switch (the one with the blue light...) none of the three magic-packet utilities I have tested can make it wake up.
The primary reason I would want to wake it up would be during the wee hours of the morning when it has shut itself down per the Power schedule and has not turned itself back on yet.
Power outages, seems like it's OK bc it auto-boots when power is restored after (figuratively) having had the plug pulled.
Is it just me?
