PeteCress
Jan 06, 2011Apprentice
Wake-On-LAN: Anybody Got It Working?
Seems like WOL is the only game in town for remote recovery from a power failure ==> graceful shutdown in response to UPS. I'm doing something wrong, but don't know what. Using Fusion's "FUSION ...
fbmachines
Feb 09, 2011Guide
trackless wrote: WOL does not work when I have LACP enabled on my ReadyNAS 3100 NICs. If I disable LACP on the switch (NETGEAR GS748Tv3), WOL will work but then I can't access my NAS until I re-enable LACP on the switch.
When I use just a single NIC, it works everytime.
RAIDiator x86 Firware: 4.2.15
I have LACP enabled also.
Local WOL works flawless for me but the only way I can get WOL to work over the internet is to enable root SSH on the NAS. Is this normal? I have of course forwarded the necessary ports I am using for WOL to the NAS's LAN IP. I am testing this on a Pro-2 and Pro-6 with a ProSecure UTM25 router.
Edit: after further testing , it appears to be the same problem as listed in previous posts. The WAN WOL only works when powered down by the admin interface. When it is powered down via the power button, no WAN WOL only LAN WOL.
Hope this gets worked out quickly.
