Ntemis
Jul 28, 2018Tutor
Wake On Lan doesnt work from eth1.
As the title says i have to connect cable to eth0 to see any lights on after shutdown the unit.
Wake on Lan doesnt work when cable is attached to eth1. I have latest ReadyNAS OS 6 v6.9.3
Thank yo...
Ntemis
Jul 28, 2018Tutor
No its not.
Settings for eth1:
Supported ports: [ TP ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
Supported pause frame use: No
Supports auto-negotiation: Yes
Advertised link modes: Not reported
Advertised pause frame use: No
Advertised auto-negotiation: No
Speed: Unknown!
Duplex: Unknown! (255)
Port: Twisted Pair
PHYAD: 0
Transceiver: internal
Auto-negotiation: on
MDI-X: Unknown
Supports Wake-on: g
Wake-on: g
Link detected: no
Jul 28, 2018Guru - Experienced User
Netgear says otherwise: https://kb.netgear.com/de/22106/Wie-aktiviere-ich-Wake-on-LAN-auf-dem-ReadyNAS-der-Serie-Ultra-Ultra-Plus-NVX-Pioneer-oder-Pro-Pioneer
"Das ReadyNAS-System unterstützt Wake-on-LAN nur am ersten Netzwerkanschluss (LAN 1)" which translates to "The ReadyNAS system supports wake-on-LAN only on the first network port (LAN 1)".
Wake-on-Lan requires bios support in addition to support on the NIC itself.
Unfortunately Netgear has removed many of the older kb articles (including the english version of this one).
- NtemisJul 28, 2018Tutor
I have the latest bios or do i?
Version: 06/10/2010 FLAME6-2 V1.1
BIOS Revision: 8.16
Is there any newer bios out that can make eth1 wol work?
- StephenBJul 28, 2018Guru - Experienced User
Look in bios_settings.log (in the log zip file) and post the date of your bios.
Ntemis wrote:Is there any newer bios out that can make eth1 wol work?
AFAIK there is no bios available that will make eth1 wol work. Hopefully mdgm-ntgr or another Netgear mod will chime in.
Both ethX are:
Ethernet controller: Marvell Technology Group Ltd. 88E8057 PCI-E Gigabit Ethernet Controller (rev 10)
I dont get why 1st one works and second one doesnt.
