stevio
Feb 01, 2015Aspirant
Wake on LAN stopped working on my RN102
Does anyone else currently use WoL on their RN102? I used to use it occasionally, and I can't think what's changed since I last used it. Possibly the 6.2.2 firmware update? I'm using the SimpleWo...
stevio
Feb 04, 2015Aspirant
Thank you very much, it's now working! :D
After using the Windows tool it made me realise that SimpleWoL was a bit too simple and did not allow the configuration of subnet or broadcast. I now have an app called RemoteBoot which is working perfectly.
Thank you for your time and all of the information you've provided to get to the bottom of this problem.
