CharlesR
Nov 13, 2014Guide
Wake On Lan
I have been using Wake On Lan rather nicely with 6.x on various Legacy devices. Up to now all of them have used only one Ethernet connection. Now I'm using a Ultra 6 with both NICs bonded as Adaptive ...
CharlesR
Nov 13, 2014Guide
Per the first post... Adaptive Load Balancing
I just tried removing the bond and rebooting the NAS. Didn't make any different... no luck. However the WOL app still works. I'm not sure but I think perhaps I tried when I first installed it (before trying the bond) and it didn't work... perhaps it's just not compatible hardware/software with XBMC. I have been trying via OpenELEC (Linux). I'll try the Windows version of XBMC and see if it behaves the same way.
The Windows Kodi/XBMC Beta version doesn't work either... the WOL app does work with one or two lines so obviously it's possible just not something Kodi/XBMC can handle for some reason...
