Retired_Member
Nov 08, 2017WARNING - Firmware Update 6.9.0
So, my NAS promted me to tell me that a firmware update was available and, upkeeping with the latest versions, I decided to go ahead and do the update via the web browser. Seems painless ... Aft...
Kimera
Nov 08, 2017Guide
You didn't told us which is the ReadyNAS OS software version that your NAS was running before the upgrade request to download and install latest ReadyNAS OS 6.9.0...also doing preliminary checking - through SSH - of most important log files would be helpful to understand what happened during/after the update (and Yes...knowing where to look for is important to have a smooth start...ranting isn't helpful).
mdgm-ntgr
Nov 08, 2017NETGEAR Employee Retired
These symptoms are consistent with an app wrongly changing the ownership of folders/files that it shouldn’t rather than a firmware issue.
Which apps do you have installed?
