Retired_Member
Nov 08, 2017WARNING - Firmware Update 6.9.0
So, my NAS promted me to tell me that a firmware update was available and, upkeeping with the latest versions, I decided to go ahead and do the update via the web browser. Seems painless ... Aft...
Retired_Member
Nov 08, 2017Here is an extract of the fwbroker.log:
Oct 31 2017 17:23:06 INFO:AAGET_REMOTE_INFO(STEP 1 URL:) https://update.readynas.com/download/ReadyNASOS-arm/index?key=d4cd51e5cc36bb0736f67eb9123ae453&model=ReadyNAS&model_num=104¤t_version=6.8.1
Oct 31 2017 17:23:08 answer=info::name=ReadyNASOS,version=6.9.0,time=1507942835,size=68184064,md5sum=3ec076c7638efe8c6db2086fd44109cf,arch=arm,descr=ReadyNASOS Update,release_notes=https://kb.netgear.com/000049516/ReadyNAS-OS-6-Software-Version-6-9-0
From the timestamps, the NAS was running 6.8.1 and prompted an update to 6.9.0.
As for what happened next, who knows. What I can say is, the NAS worked fine before, and after the update doesn't!
But hey, here's the question: why woud the /var, /sys, /etc directories need to be owned by guest? They wouldn't. If the config files for these services isn't owned by root (or at least admin) then none of the services will work.
Apology for the rant, but yeah, after what should be a simple a update, needing to spend a week on data recovery does tend put you in a bad mood :-)
Kudos
mdgm-ntgr
Nov 08, 2017NETGEAR Employee Retired
Again, this is consistent with a bad app, not a problem with the firmware. This is my experience from every time I’ve seen a customer have this issue.
- Retired_MemberNov 08, 2017
Just seen this comment.
Only App I run on the NAS is Plex Media (had it running for years) to stream Music/Video around the House. It runs seemlessly in the background, with little (if any) effort needed to maintain.
Only other App I've looked at is Rsyslog to see if I can make any use of it. Rsyslog was installed from the NAS app store and, after checking, removed because I can't make any use of it.
If this were App related, then suppose fundementally the question would be how did an App get into the Netgear App store that has the potential to not only break the NAS, but change the permissions on every single file/folder on the device? Surely they're tested to make sure they don't introduce such critical vulnerability before being released?
If not App related, then the point still stands re Firmware update.
- mdgm-ntgrNov 08, 2017NETGEAR Employee Retired
It wouldn’t be the Plex app, but rather a different app.
Which version of the apps did you have installed?
Some old versions of some apps (e.g. Transmission) had this issue.
Similar to firmware, as and when Plex notifies me of an update I install it so Plex would have been running the latest version.
Thing with Apps, I use the NAS to store kids school work, my contract work, family photos etc as well as Music/Video's etc. So I tend to avoid installig apps unless I think I can make use of them. Hence Rsyslog.
How possible is it to get hold of a RN104 running 6.8.1 and install Rsyslog to observe the behaviour, if nothing else to validate the App?
