x219c
Feb 13, 2023Luminary
Way to determine drive order?
My drives were removed, and although I thought they were put back in the correct order, apparently they weren't. I saw where a jedi mentioned it was possible for a tech support member to determine wh...
- Feb 13, 2023
One option is to remove the drives from the RN316 and then do a factory default with just a single spare drive in place. Then see what happens with the EDA volume.
It might also be possible to remount the RN516 volume. Do you have a log zip file?
Netgear's data recovery service might also be an option here, though the initial assessment would cost $200 USD.
x219c
It's a 516 running the latest firmware. I'm thinking the drives may have been corrupted in this case... That's really too bad.
x219c
The longer version is: I got a newer NAS, and I plan to use these drives in there. I had all of my important data backed up, but there was some that's technically replaceable. I'd rather not have to, though.... So I hooked up my EDA enclosure and transferred the data there and exported it. Then I took my drives from the system and put them in the new system, but didn't set anything up. (it probably did something anyway, is my thought)
Anyway, I plugged my EDA into another system, and that volume doesn't show up either. Those drives weren't moved or anything other than plugging the unit into my 316. I thought, okay, I better move my drives back and rsync it to a different server... but it wouldn't take the drives gracefully.
Now I guess that's the only way to get that data back is to see why my eda volume isn't showing up.
- x219cFeb 13, 2023Luminary
Follow up, I suppose... The only reason I can reasonably think the 316 won't accept my eda enclosure is the name may have previously been used... Not positive. But with that theory in mind, is there a way to get rid of the stored names from the past?
- StephenBFeb 13, 2023Guru - Experienced User
Well, I think you might be onto something... I have a lot of my data on the 316 currently. But, I could initialize the 516 with one drive and see if it'd use the EDA. That's a great idea. Thank you Stephen.
As far as my drives, I think they are just gone now. I put them in a QNAP, which may or may not have started some initial phase to get them ready for the new system. Although I didn't even log in to move forward, I suspect that's probably what happened. Even if I could get the drives back, it really wouldn't matter. Like I said, it's replaceable data, I'd just rather not have to. All of my important data is backed up.
