SisyphusBond
Apr 09, 2018Aspirant
Web interface and installing, updating and removing apps
I have a ReadyNAS 214 running 6.9.3 Back when it was on 6.8.0 (I think) I was one of the people who had trouble with installing and updating apps via the web interface. When the OS updated and th...
Retired_Member
May 24, 2018Assuming you have a good backup, why not trying the downgrade/upgrade-the-firmware-approach. It helped for example in the case below:
- StephenBMay 24, 2018Guru - Experienced User
That resolved a very different problem, and I don't think it's likely to resolve this one.
If you do want to try it, don't try to downgrade back to 6.8.0. You'd need to stay within 6.9.x. I'd also suggest doing a simple OS-reinstall first (which I think has about the same odds of fixing it, but is less likely to make things worse).
Since you have apps installed, I suggest checking for OS partition fullness first - download the log zip file, and look in volume.log. The section you want starts with
=== df -h ===
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 955M 2.7G 26% /Look at the fullness of /dev/md0 - it's normally around 25% full. If it's over 50% full, you should probably clean it.
- SisyphusBondJun 17, 2018Aspirant
StephenB wrote:
Since you have apps installed, I suggest checking for OS partition fullness first - download the log zip file, and look in volume.log. The section you want starts with=== df -h ===
It is indeed currently showing 53%. How exactly do I clean it?
Sorry for coming back to this two months later. My work schedule got busy and I had to put this aside for a while.
- StephenBJun 18, 2018Guru - Experienced User
SisyphusBond wrote: It is indeed currently showing 53%. How exactly do I clean it?Basically you need to use ssh to find out where the space is going. What you do depends on where/what the files are.
Mitigations include
- deleting temp files (for instance core files) or cache
- uninstalling apps
- replacing some app folders with symlinks to the data volume
- deleting files under system mount points (a bit tricky to find)
- truncating unrotated log files
The other approach is to bite the bullet and do the factory reset. Then reconfigure the NAS, and reload the files from your backup.
